Retrieve an external NTP server configuration
GET /cluster/ntp/servers/{server}
Introduced In: 9.7
Retrieves the configuration of an external NTP server used by ONTAP.
Related ONTAP commands
cluster time-service ntp server show
Learn more
server  |
string  |
path  |
True  |
NTP server host name, IPv4, or IPv6 address.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
authentication_enabled  |
boolean  |
Set NTP symmetric authentication on (true) or off (false).  |
key  |
server  |
string  |
version  |
string  |
NTP protocol version for server. Valid versions are 3, 4, or auto.  |
      "href": "/api/resourcelink"
  "authentication_enabled": 1,
  "key": {
    "id": 10
  "server": "time.nist.gov",
  "version": "auto"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
ntp_key_reference
_links  |
id  |
integer  |
NTP symmetric authentication key identifier or index number (ID). This ID, the type of cryptographic hash, and the cryptographic hash value are all provided by the remote NTP server.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
