Retrieve an external NTP server configuration
Retrieves the configuration details of an external NTP server. This information helps ensure accurate time synchronization across your ONTAP systems.
HTTP method and endpoint
GET /cluster/ntp/servers/{server}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the configuration of an external NTP server used by ONTAP.
Related ONTAP commands
cluster time-service ntp server show
Learn more
server |
string |
path |
True |
NTP server host name, IPv4, or IPv6 address. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
authentication_enabled |
boolean |
Set NTP symmetric authentication on (true) or off (false). |
key |
server |
string |
version |
string |
NTP protocol version for server. Valid versions are 3, 4, or auto. |
"href": "/api/resourcelink"
"authentication_enabled": 1,
"key": {
"id": 10
"server": "time.nist.gov",
"version": "auto"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ntp_key_reference
_links |
id |
integer |
NTP symmetric authentication key identifier or index number (ID). This ID, the type of cryptographic hash, and the cryptographic hash value are all provided by the remote NTP server. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
