Retrieve environment sensors
Retrieves environment sensors to access data on the current status and readings from the sensors in your ONTAP system. This information helps you monitor environmental conditions and ensure system health.
HTTP method and endpoint
GET /cluster/sensors
Introduced in
ONTAP 9.11
Usage notes
Retrieve Environment Sensors
warning_high_threshold |
integer |
query |
False |
Filter by warning_high_threshold |
value_units |
string |
query |
False |
Filter by value_units |
value |
integer |
query |
False |
Filter by value |
type |
string |
query |
False |
Filter by type |
critical_high_threshold |
integer |
query |
False |
Filter by critical_high_threshold |
warning_low_threshold |
integer |
query |
False |
Filter by warning_low_threshold |
discrete_value |
string |
query |
False |
Filter by discrete_value |
index |
integer |
query |
False |
Filter by index |
critical_low_threshold |
integer |
query |
False |
Filter by critical_low_threshold |
name |
string |
query |
False |
Filter by name |
discrete_state |
string |
query |
False |
Filter by discrete_state |
threshold_state |
string |
query |
False |
Filter by threshold_state |
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[sensors] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"critical_high_threshold": 0,
"critical_low_threshold": 0,
"discrete_state": "normal",
"discrete_value": "ok",
"index": 0,
"name": "PVCCSA CPU FD",
"node": {
"name": "node1",
"threshold_state": "normal",
"type": "string",
"value": 831,
"value_units": "mV",
"warning_high_threshold": 0,
"warning_low_threshold": 0
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
sensors
Environment Sensors
_links |
integer |
Value above which the sensor goes into a critically high state. |
integer |
Value below which the sensor goes into a critically low state. |
discrete_state |
string |
Used to determine whether the sensor is in a normal state or any other failed state based on the value of "discrete_value" field. This field is only applicable for discrete sensors. |
discrete_value |
string |
Applies to discrete sensors which do not have an integer value. It can have values like on, off, good, bad, ok. |
index |
integer |
Provides the sensor ID. |
name |
string |
Name of the sensor. |
node |
threshold_state |
string |
Used to determine whether the sensor is in a normal state or any other failed state. |
type |
string |
Used to detrmine the type of the sensor. |
value |
integer |
Provides the sensor reading. |
value_units |
string |
Units in which the "value" is measured. Some examples of units are mV, mW*hr, C, RPM. |
integer |
Value above which the sensor goes into a warning high state. |
integer |
Value below which the sensor goes into a warning low state. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
