Retrieve environment sensors
Retrieves information about environment sensors, which helps you monitor and manage environmental conditions effectively.
HTTP method and endpoint
GET /cluster/sensors
Introduced in
ONTAP 9.11
Usage notes
Retrieve Environment Sensors
critical_low_threshold |
integer |
query |
False |
Filter by critical_low_threshold |
warning_high_threshold |
integer |
query |
False |
Filter by warning_high_threshold |
type |
string |
query |
False |
Filter by type |
threshold_state |
string |
query |
False |
Filter by threshold_state |
index |
integer |
query |
False |
Filter by index |
value |
integer |
query |
False |
Filter by value |
discrete_value |
string |
query |
False |
Filter by discrete_value |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
value_units |
string |
query |
False |
Filter by value_units |
critical_high_threshold |
integer |
query |
False |
Filter by critical_high_threshold |
name |
string |
query |
False |
Filter by name |
warning_low_threshold |
integer |
query |
False |
Filter by warning_low_threshold |
discrete_state |
string |
query |
False |
Filter by discrete_state |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[sensors] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"critical_high_threshold": 0,
"critical_low_threshold": 0,
"discrete_state": "normal",
"discrete_value": "ok",
"index": 0,
"name": "PVCCSA CPU FD",
"node": {
"name": "node1",
"threshold_state": "normal",
"type": "string",
"value": 831,
"value_units": "mV",
"warning_high_threshold": 0,
"warning_low_threshold": 0
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
sensors
Environment Sensors
_links |
integer |
Value above which the sensor goes into a critically high state. |
integer |
Value below which the sensor goes into a critically low state. |
discrete_state |
string |
Used to determine whether the sensor is in a normal state or any other failed state based on the value of "discrete_value" field. This field is only applicable for discrete sensors. |
discrete_value |
string |
Applies to discrete sensors which do not have an integer value. It can have values like on, off, good, bad, ok. |
index |
integer |
Provides the sensor ID. |
name |
string |
Name of the sensor. |
node |
threshold_state |
string |
Used to determine whether the sensor is in a normal state or any other failed state. |
type |
string |
Used to detrmine the type of the sensor. |
value |
integer |
Provides the sensor reading. |
value_units |
string |
Units in which the "value" is measured. Some examples of units are mV, mW*hr, C, RPM. |
integer |
Value above which the sensor goes into a warning high state. |
integer |
Value below which the sensor goes into a warning low state. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
