REST API reference
Retrieve environment sensors
GET /cluster/sensors
Introduced In: 9.11
Retrieves Environment Sensors
  • system node environment sensors show
warning_high_threshold
integer
query
False
Filter by warning_high_threshold
type
string
query
False
Filter by type
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
discrete_value
string
query
False
Filter by discrete_value
critical_high_threshold
integer
query
False
Filter by critical_high_threshold
threshold_state
string
query
False
Filter by threshold_state
name
string
query
False
Filter by name
value
integer
query
False
Filter by value
critical_low_threshold
integer
query
False
Filter by critical_low_threshold
index
integer
query
False
Filter by index
discrete_state
string
query
False
Filter by discrete_state
value_units
string
query
False
Filter by value_units
warning_low_threshold
integer
query
False
Filter by warning_low_threshold
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[sensors]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "critical_high_threshold": 0,
      "critical_low_threshold": 0,
      "discrete_state": "normal",
      "discrete_value": "ok",
      "index": 0,
      "name": "PVCCSA CPU FD",
      "node": {
        "name": "node1",
      "threshold_state": "normal",
      "type": "string",
      "value": 831,
      "value_units": "mV",
      "warning_high_threshold": 0,
      "warning_low_threshold": 0
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
node
_links
_links
name
string
uuid
string
sensors
Environment Sensors
_links
self_link
integer
Value above which the sensor goes into a critically high state.
integer
Value below which the sensor goes into a critically low state.
discrete_state
string
Used to determine whether the sensor is in a normal state or any other failed state based on the value of "discrete_value" field. This field is only applicable for discrete sensors.
discrete_value
string
Applies to discrete sensors which do not have an integer value. It can have values like on, off, good, bad, ok.
index
integer
Provides the sensor ID.
name
string
Name of the sensor.
node
node
threshold_state
string
Used to determine whether the sensor is in a normal state or any other failed state.
type
string
Used to determine the type of the sensor.
value
integer
Provides the sensor reading.
value_units
string
Units in which the "value" is measured. Some examples of units are mV, mW*hr, C, RPM.
integer
Value above which the sensor goes into a warning high state.
integer
Value below which the sensor goes into a warning low state.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
