Retrieve group membership cache settings
Retrieves the group membership cache settings to understand the current caching configuration for group memberships. This helps you manage and optimize name service operations in your environment.
HTTP method and endpoint
GET /name-services/cache/group-membership/settings
Introduced in
ONTAP 9.11
Usage notes
Retrieves group-membership cache settings.
Related ONTAP commands
vserver services name-service cache group-membership settings show
enabled |
boolean |
query |
False |
Filter by enabled |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
ttl |
string |
query |
False |
Filter by ttl |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[group_membership_settings] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"svm": {
"name": "svm1",
"ttl": "PT2H30M"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
Group membership cache setting.
_links |
enabled |
boolean |
Specifies whether or not the cache is enabled. |
svm |
ttl |
string |
Specifies Time to Live for list of group members, in ISO 8601 format. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
