REST API reference
Retrieve group membership cache settings
Retrieves the group membership cache settings to access the current configuration for managing cached group memberships.
HTTP method and endpoint
GET /name-services/cache/group-membership/settings
Introduced in
ONTAP 9.11
Usage notes
Retrieves group-membership cache settings.
  • vserver services name-service cache group-membership settings show
enabled
boolean
query
False
Filter by enabled
ttl
string
query
False
Filter by ttl
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[group_membership_settings]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "svm": {
        "name": "svm1",
      "ttl": "PT2H30M"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
Group membership cache setting.
_links
_links
enabled
boolean
Specifies whether or not the cache is enabled.
svm
svm
ttl
string
Specifies Time to Live for list of group members, in ISO 8601 format.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
