Retrieve group membership cache settings
Obtains the current settings for the group membership cache, which helps manage how group membership information is cached for improved lookup efficiency.
HTTP method and endpoint
GET /name-services/cache/group-membership/settings
Introduced in
ONTAP 9.11
Usage notes
Retrieves group-membership cache settings.
Related ONTAP commands
vserver services name-service cache group-membership settings show
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
ttl |
string |
query |
False |
Filter by ttl |
enabled |
boolean |
query |
False |
Filter by enabled |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[group_membership_settings] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"svm": {
"name": "svm1",
"ttl": "PT2H30M"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
uuid |
string |
Group membership cache setting.
_links |
enabled |
boolean |
Specifies whether or not the cache is enabled. |
svm |
ttl |
string |
Specifies Time to Live for list of group members, in ISO 8601 format. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
