Retrieve users for a UNIX group and SVM
GET /name-services/unix-groups/{svm.uuid}/{unix_group.name}/users
Introduced In: 9.10
Retrieves users for the specified UNIX group and SVM.
Related ONTAP commands
vserver services name-service unix-group show
unix_group.name |
string |
path |
True |
UNIX group name. |
name |
string |
query |
False |
Filter by name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of UNIX user records in a given SVM and group. |
records |
array[unix_group_users] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"name": "string",
"skip_name_validation": null,
"svm": {
"name": "svm1",
"unix_group": {
"name": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
records
name |
string |
UNIX user who belongs to the specified UNIX group and the SVM. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
unix_group
name |
string |
UNIX group name. |
unix_group_users
_links |
name |
string |
svm |
unix_group |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
