Retrieve users for a UNIX group and SVM
GET /name-services/unix-groups/{svm.uuid}/{unix_group.name}/users
Introduced In: 9.10
Retrieves users for the specified UNIX group and SVM.
Related ONTAP commands
vserver services name-service unix-group show
unix_group.name  |
string  |
path  |
True  |
UNIX group name.  |
name  |
string  |
query  |
False  |
Filter by name  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of UNIX user records in a given SVM and group.  |
records  |
array[unix_group_users]  |
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "name": "string",
      "skip_name_validation": true,
      "svm": {
        "name": "svm1",
      "unix_group": {
        "name": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
records
name  |
string  |
UNIX user who belongs to the specified UNIX group and the SVM.  |
svm
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
unix_group
name  |
string  |
UNIX group name.  |
unix_group_users
_links  |
name  |
string  |
svm  |
SVM, applies only to SVM-scoped objects.  |
unix_group  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
