REST API reference
Retrieve users for a UNIX group and SVM
GET /name-services/unix-groups/{svm.uuid}/{unix_group.name}/users
Introduced In: 9.10
Retrieves users for the specified UNIX group and SVM.
  • vserver services name-service unix-group show
unix_group.name
string
path
True
UNIX group name.
name
string
query
False
Filter by name
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 1
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of UNIX user records in a given SVM and group.
records
array[unix_group_users]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "name": "string",
      "skip_name_validation": true,
      "svm": {
        "name": "svm1",
      "unix_group": {
        "name": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
records
name
string
UNIX user who belongs to the specified UNIX group and the SVM.
svm
_links
_links
name
string
uuid
string
unix_group
name
string
UNIX group name.
unix_group_users
_links
_links
name
string
svm
svm
unix_group
unix_group
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
