Retrieve details of a BGP peer group for VIP
GET /network/ip/bgp/peer-groups/{uuid}
Introduced In: 9.7
Retrieves details of a BGP peer group for VIP.
Related ONTAP commands
network bgp peer-group show
uuid  |
string  |
path  |
True  |
UUID of the peer group  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
ipspace  |
Either the UUID or name is supplied on input.  |
local  |
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address.  |
name  |
string  |
Name of the peer group  |
peer  |
Information describing the router to peer with  |
state  |
string  |
State of the peer group  |
uuid  |
string  |
  "ipspace": {
        "href": "/api/resourcelink"
    "name": "exchange",
  "local": {
    "interface": {
      "ip": {
        "address": "10.10.10.7"
      "name": "lif1",
    "port": {
      "name": "e1b",
      "node": {
        "name": "node1"
  "name": "bgpv4peer",
  "peer": {
  "state": "string",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
ipspace
_links  |
name  |
string  |
IPspace name  |
uuid  |
string  |
IPspace UUID  |
ip
IP information
address  |
string  |
IPv4 or IPv6 address  |
interface
_links  |
ip  |
IP information  |
name  |
string  |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.  |
uuid  |
string  |
The UUID that uniquely identifies the interface.  |
ip
IP information to create a new interface.
address  |
string  |
netmask  |
string  |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.  |
node
name  |
string  |
Name of node on which the port is located.  |
port
_links  |
name  |
string  |
node  |
uuid  |
string  |
local
interface  |
port  |
peer
address  |
string  |
Peer router address  |
asn  |
integer  |
Autonomous system number of peer  |
is_next_hop  |
boolean  |
Use peer address as next hop.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
