Retrieve details of a BGP peer group for VIP
Retrieves details about a BGP peer group for a virtual IP (VIP) to understand its configuration and operational state.
HTTP method and endpoint
GET /network/ip/bgp/peer-groups/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Retrieves details of a BGP peer group for VIP.
Related ONTAP commands
network bgp peer-group show
uuid |
string |
path |
True |
UUID of the peer group |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
ipspace |
Either the UUID or name is supplied on input. |
local |
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address. |
name |
string |
Name of the peer group |
peer |
Information describing the router to peer with |
state |
string |
State of the peer group |
uuid |
string |
"ipspace": {
"href": "/api/resourcelink"
"name": "Default",
"local": {
"interface": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"port": {
"name": "e1b",
"node": {
"name": "node1"
"name": "bgpv4peer",
"peer": {
"address": "10.10.10.7",
"md5_enabled": 1,
"md5_secret": "SECRET_WORD"
"state": "string",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
A network interface. Either UUID or name may be supplied on input.
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
ip
IP information to create a new interface.
address |
string |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
node
name |
string |
Name of node on which the port is located. |
port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links |
name |
string |
node |
uuid |
string |
local
interface |
A network interface. Either UUID or name may be supplied on input. |
port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
peer
address |
string |
Peer router address |
asn |
integer |
Autonomous system number of peer |
is_next_hop |
boolean |
Use peer address as next hop. |
md5_enabled |
boolean |
Enable or disable TCP MD5 signatures per RFC 2385. |
md5_secret |
string |
The shared TCP MD5 secret key. This can either be given as a password or hexadecimal key. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
