REST API reference
Retrieve details of a BGP peer group for VIP
Retrieves details about a BGP peer group for a virtual IP (VIP) to understand its configuration and operational state.
HTTP method and endpoint
GET /network/ip/bgp/peer-groups/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Retrieves details of a BGP peer group for VIP.
  • network bgp peer-group show
uuid
string
path
True
UUID of the peer group
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
ipspace
ipspace
Either the UUID or name is supplied on input.
local
local
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address.
name
string
Name of the peer group
peer
peer
Information describing the router to peer with
state
string
State of the peer group
uuid
string
  "ipspace": {
        "href": "/api/resourcelink"
    "name": "Default",
  "local": {
    "interface": {
      "ip": {
        "address": "10.10.10.7"
      "name": "lif1",
    "port": {
      "name": "e1b",
      "node": {
        "name": "node1"
  "name": "bgpv4peer",
  "peer": {
    "address": "10.10.10.7",
    "md5_enabled": 1,
    "md5_secret": "SECRET_WORD"
  "state": "string",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
ip
IP information
address
string
IPv4 or IPv6 address
interface
A network interface. Either UUID or name may be supplied on input.
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
ip
IP information to create a new interface.
address
string
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
node
name
string
Name of node on which the port is located.
port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links
_links
name
string
node
node
uuid
string
local
interface
interface
port
port
peer
address
string
Peer router address
asn
integer
Autonomous system number of peer
is_next_hop
boolean
Use peer address as next hop.
md5_enabled
boolean
Enable or disable TCP MD5 signatures per RFC 2385.
md5_secret
string
The shared TCP MD5 secret key. This can either be given as a password or hexadecimal key.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
