REST API reference
Retrieve IP routes
Retrieves the collection of IP routes to examine the network paths your system is using for communication.
HTTP method and endpoint
GET /network/ip/routes
Introduced in
ONTAP 9.6
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • interfaces.*
  • network route show
  • network route show-lifs
gateway
string
query
False
Filter by gateway
destination.address
string
query
False
Filter by destination.address
destination.family
string
query
False
Filter by destination.family
destination.netmask
string
query
False
Filter by destination.netmask
interfaces.uuid
string
query
False
Filter by interfaces.uuid
  • Introduced in: 9.9
interfaces.ip.address
string
query
False
Filter by interfaces.ip.address
interfaces.name
string
query
False
Filter by interfaces.name
scope
string
query
False
Filter by scope
ipspace.uuid
string
query
False
Filter by ipspace.uuid
ipspace.name
string
query
False
Filter by ipspace.name
uuid
string
query
False
Filter by uuid
metric
integer
query
False
Filter by metric
  • Introduced in: 9.11
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
error
error
num_records
integer
Number of records
records
array[network_route]
    "next": {
      "href": "/api/resourcelink"
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
  "num_records": 1,
  "records": [
      "destination": {
        "address": "10.10.10.7",
        "family": "string",
        "netmask": "24"
      "gateway": "10.1.1.1",
      "interfaces": [
          "ip": {
          "name": "lif1",
      "ipspace": {
        "name": "exchange",
      "scope": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
self
ip_info
IP information
address
string
IPv4 or IPv6 address
family
string
IPv4 or IPv6
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
ip
IP information
address
string
interfaces
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
svm
_links
_links
name
string
The name of the SVM.
uuid
string
network_route
_links
_links
destination
ip_info
IP information
gateway
string
The IP address of the gateway router leading to the destination.
interfaces
array[interfaces]
IP interfaces on the same subnet as the gateway.
ipspace
ipspace
metric
integer
Indicates a preference order between several routes to the same destination. With typical usage, the default metrics provided are adequate, there is no need to specify a metric in the route creation.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
svm
svm
uuid
string
The UUID that uniquely identifies the route.
