Retrieve IP routes
Retrieves IP routes to examine the network paths configured in the system. Use this information to assess and manage network routing configurations effectively.
HTTP method and endpoint
GET /network/ip/routes
Introduced in
ONTAP 9.6
Usage notes
Retrieves the collection of IP routes.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
interfaces.*
Related ONTAP commands
network route show -
network route show-lifs
destination.netmask |
string |
query |
False |
Filter by destination.netmask |
destination.family |
string |
query |
False |
Filter by destination.family |
destination.address |
string |
query |
False |
Filter by destination.address |
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid |
ipspace.name |
string |
query |
False |
Filter by ipspace.name |
gateway |
string |
query |
False |
Filter by gateway |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
uuid |
string |
query |
False |
Filter by uuid |
scope |
string |
query |
False |
Filter by scope |
interfaces.ip.address |
string |
query |
False |
Filter by interfaces.ip.address
interfaces.name |
string |
query |
False |
Filter by interfaces.name
interfaces.uuid |
string |
query |
False |
Filter by interfaces.uuid
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
error |
num_records |
integer |
Number of records |
records |
array[network_route] |
"next": {
"href": "/api/resourcelink"
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"num_records": "1",
"records": [
"destination": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"gateway": "10.1.1.1",
"interfaces": [
"ip": {
"name": "lif1",
"ipspace": {
"name": "exchange",
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
_links
self |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
ip
IP information
address |
string |
interfaces
_links |
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
network_route
_links |
destination |
IP information |
gateway |
string |
The IP address of the gateway router leading to the destination. |
interfaces |
array[interfaces] |
IP interfaces on the same subnet as the gateway. |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
uuid |
string |
The UUID that uniquely identifies the route. |
