Retrieve IP routes
Retrieves the collection of IP routes to view the network routing configuration. Use this information to understand how network traffic is directed within your environment.
HTTP method and endpoint
GET /network/ip/routes
Introduced in
ONTAP 9.6
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
interfaces.*
Related ONTAP commands
network route show -
network route show-lifs
uuid |
string |
query |
False |
Filter by uuid |
gateway |
string |
query |
False |
Filter by gateway |
interfaces.ip.address |
string |
query |
False |
Filter by interfaces.ip.address
interfaces.name |
string |
query |
False |
Filter by interfaces.name
interfaces.uuid |
string |
query |
False |
Filter by interfaces.uuid
destination.netmask |
string |
query |
False |
Filter by destination.netmask |
destination.address |
string |
query |
False |
Filter by destination.address |
destination.family |
string |
query |
False |
Filter by destination.family |
scope |
string |
query |
False |
Filter by scope |
metric |
integer |
query |
False |
Filter by metric
ipspace.name |
string |
query |
False |
Filter by ipspace.name |
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
error |
num_records |
integer |
Number of records |
records |
array[network_route] |
"next": {
"href": "/api/resourcelink"
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"num_records": 1,
"records": [
"destination": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"gateway": "10.1.1.1",
"interfaces": [
"ip": {
"name": "lif1",
"ipspace": {
"name": "exchange",
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
_links
self |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
ip
IP information
address |
string |
interfaces
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
Applies only to SVM-scoped objects. Either the UUID or name must be supplied.
_links |
name |
string |
The name of the SVM. |
uuid |
string |
network_route
_links |
destination |
IP information |
gateway |
string |
The IP address of the gateway router leading to the destination. |
interfaces |
array[interfaces] |
IP interfaces on the same subnet as the gateway. |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input. |
metric |
integer |
Indicates a preference order between several routes to the same destination. With typical usage, the default metrics provided are adequate, there is no need to specify a metric in the route creation. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
Applies only to SVM-scoped objects. Either the UUID or name must be supplied. |
uuid |
string |
The UUID that uniquely identifies the route. |
