REST API reference
Retrieve IP subnet details
Accesses specific IP subnet details to review configuration and status information for network management.
HTTP method and endpoint
GET /network/ip/subnets/{uuid}
Introduced in
ONTAP 9.11
Usage notes
Retrieves details for a specific IP subnet.
  • network subnet show
uuid
string
path
True
IP subnet UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
available_count
integer
available_ip_ranges
array[ip_address_range]
broadcast_domain
broadcast_domain
The broadcast domain that the subnet is associated with. Either the UUID or name must be supplied on POST.
gateway
string
The IP address of the gateway for this subnet.
ip_ranges
ipspace
ipspace
The IPspace that the subnet is associated with. Either the UUID or name must be supplied on POST.
name
string
Subnet name
subnet
ip_info
IP information
total_count
integer
used_count
integer
uuid
string
The UUID that uniquely identifies the subnet.
      "href": "/api/resourcelink"
  "available_count": 0,
  "available_ip_ranges": [
      "end": "10.10.10.7",
      "family": "string",
      "start": "10.10.10.7"
  "broadcast_domain": {
    "name": "bd1",
  "fail_if_lifs_conflict": true,
  "gateway": "10.1.1.1",
  "ip_ranges": [
      "family": "string",
  "ipspace": {
    "name": "exchange",
  "name": "subnet1",
  "subnet": {
    "address": "10.10.10.7",
    "family": "string",
    "netmask": "24"
  "total_count": 0,
  "used_count": 0,
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ip_address_range
IP address range
end
string
IPv4 or IPv6 address
family
string
IPv4 or IPv6
start
string
broadcast_domain
_links
_links
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
Broadcast domain UUID
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
ip_info
IP information
address
string
family
string
IPv4 or IPv6
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
