Retrieve IP subnet details
GET /network/ip/subnets/{uuid}
Introduced In: 9.11
Retrieves details for a specific IP subnet.
Related ONTAP commands
network subnet show
uuid  |
string  |
path  |
True  |
IP subnet UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
available_count  |
integer  |
available_ip_ranges  |
array[ip_address_range]  |
broadcast_domain  |
The broadcast domain that the subnet is associated with. Either the UUID or name must be supplied on POST.  |
gateway  |
string  |
The IP address of the gateway for this subnet.  |
ip_ranges  |
ipspace  |
The IPspace that the subnet is associated with. Either the UUID or name must be supplied on POST.  |
name  |
string  |
Subnet name  |
subnet  |
IP information  |
total_count  |
integer  |
used_count  |
integer  |
uuid  |
string  |
The UUID that uniquely identifies the subnet.  |
      "href": "/api/resourcelink"
  "available_count": 0,
  "available_ip_ranges": [
      "end": "10.10.10.7",
      "family": "string",
      "start": "10.10.10.7"
  "broadcast_domain": {
    "name": "bd1",
  "fail_if_lifs_conflict": true,
  "gateway": "10.1.1.1",
  "ip_ranges": [
      "family": "string",
  "ipspace": {
    "name": "Default",
  "name": "subnet1",
  "subnet": {
    "address": "10.10.10.7",
    "family": "string",
    "netmask": "24"
  "total_count": 0,
  "used_count": 0,
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
ip_address_range
IP address range
end  |
string  |
IPv4 or IPv6 address  |
family  |
string  |
IPv4 or IPv6  |
start  |
string  |
broadcast_domain
_links  |
name  |
string  |
Name of the broadcast domain, scoped to its IPspace  |
uuid  |
string  |
Broadcast domain UUID  |
ipspace
_links  |
name  |
string  |
IPspace name  |
uuid  |
string  |
IPspace UUID  |
ip_info
IP information
address  |
string  |
family  |
string  |
IPv4 or IPv6  |
netmask  |
string  |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
