Retrieve IP subnet details
Accesses specific IP subnet details to review configuration and status information for network management.
HTTP method and endpoint
GET /network/ip/subnets/{uuid}
Introduced in
ONTAP 9.11
Usage notes
Retrieves details for a specific IP subnet.
Related ONTAP commands
network subnet show
uuid |
string |
path |
True |
IP subnet UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
available_count |
integer |
available_ip_ranges |
array[ip_address_range] |
broadcast_domain |
The broadcast domain that the subnet is associated with. Either the UUID or name must be supplied on POST. |
gateway |
string |
The IP address of the gateway for this subnet. |
ip_ranges |
ipspace |
The IPspace that the subnet is associated with. Either the UUID or name must be supplied on POST. |
name |
string |
Subnet name |
subnet |
IP information |
total_count |
integer |
used_count |
integer |
uuid |
string |
The UUID that uniquely identifies the subnet. |
"href": "/api/resourcelink"
"available_count": 0,
"available_ip_ranges": [
"end": "10.10.10.7",
"family": "string",
"start": "10.10.10.7"
"broadcast_domain": {
"name": "bd1",
"fail_if_lifs_conflict": true,
"gateway": "10.1.1.1",
"ip_ranges": [
"family": "string",
"ipspace": {
"name": "exchange",
"name": "subnet1",
"subnet": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"total_count": 0,
"used_count": 0,
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ip_address_range
IP address range
end |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
start |
string |
broadcast_domain
_links |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
ip_info
IP information
address |
string |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
