REST API reference
Retrieve an Active Directory account for an SVM
Retrieves the Active Directory account associated with a specified SVM to manage or verify its directory services configuration.
HTTP method and endpoint
GET /protocols/active-directory/{svm.uuid}
Introduced in
ONTAP 9.12
Usage notes
Retrieves the Active Directory account for a given SVM.
  • vserver active-directory show
  • vserver active-directory preferred-dc show
  • vserver active-directory discovered-servers show
  • vserver active-directory discovered-servers reset-servers
reset_discovered_servers
boolean
query
False
Force a rediscovery.
  • Default value:
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
discovered_servers
array[discovered_servers]
Specifies the discovered servers records.
fqdn
string
Fully qualified domain name.
name
string
Active Directory (AD) account NetBIOS name.
organizational_unit
string
Organizational unit under which the Active Directory account will be created.
preferred_dcs
array[preferred_dcs]
Specifies the preferred domain controller (DC) records.
svm
svm
  "discovered_servers": [
      "domain": "server1.com",
      "node": {
            "href": "/api/resourcelink"
        "name": "node1",
      "preference": "preferred",
      "server": {
        "ip": "7.4.3.1",
        "name": "scspk0659102001",
        "type": "kerberos"
      "state": "ok"
  "force_account_overwrite": "",
  "fqdn": "server1.com",
  "name": "account1",
  "organizational_unit": "CN=Test",
  "preferred_dcs": [
      "fqdn": "test.com",
      "server_ip": "4.4.4.4"
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
node
_links
_links
name
string
uuid
string
active_directory_discovered_server_reference
ip
string
The IP address of the server that was discovered.
name
string
Server Name
type
string
The type of the server that was discovered.
discovered_servers
domain
string
The Active Directory domain that the discovered server is a member of.
node
node
preference
string
The preference level of the server that was discovered.
server
state
string
The status of the connection to the server that was discovered.
preferred_dcs
fqdn
string
Fully Qualified Domain Name.
server_ip
string
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
