Retrieve an Active Directory account for an SVM
GET /protocols/active-directory/{svm.uuid}
Introduced In: 9.12
Retrieves the Active Directory account for a given SVM.
Related ONTAP commands
vserver active-directory show -
vserver active-directory preferred-dc show -
vserver active-directory discovered-servers show -
vserver active-directory discovered-servers reset-servers
reset_discovered_servers  |
boolean  |
query  |
False  |
Force a rediscovery.
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
array[discovered_servers]  |
Specifies the discovered servers records.  |
fqdn  |
string  |
Fully qualified domain name.  |
name  |
string  |
Active Directory (AD) account NetBIOS name.  |
organizational_unit  |
string  |
Organizational unit under which the Active Directory account will be created.  |
preferred_dcs  |
array[preferred_dcs]  |
Specifies the preferred domain controller (DC) records.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
  "discovered_servers": [
      "domain": "server1.com",
      "node": {
            "href": "/api/resourcelink"
        "name": "node1",
      "preference": "preferred",
      "server": {
        "ip": "7.4.3.1",
        "name": "scspk0659102001",
        "type": "kerberos"
      "state": "ok"
  "force_account_overwrite": "",
  "fqdn": "server1.com",
  "name": "account1",
  "organizational_unit": "CN=Test",
  "preferred_dcs": [
      "fqdn": "test.com",
      "server_ip": "4.4.4.4"
  "svm": {
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
node
_links  |
name  |
string  |
uuid  |
string  |
active_directory_discovered_server_reference
ip  |
string  |
The IP address of the server that was discovered.  |
name  |
string  |
Server Name  |
type  |
string  |
The type of the server that was discovered.  |
discovered_servers
domain  |
string  |
The Active Directory domain that the discovered server is a member of.  |
node  |
preference  |
string  |
The preference level of the server that was discovered.  |
server  |
state  |
string  |
The status of the connection to the server that was discovered.  |
preferred_dcs
fqdn  |
string  |
Fully Qualified Domain Name.  |
server_ip  |
string  |
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address.  |
svm
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
