Retrieve an Active Directory account for an SVM
GET /protocols/active-directory/{svm.uuid}
Introduced In: 9.12
Retrieves the Active Directory account for a given SVM.
Related ONTAP commands
vserver active-directory show -
vserver active-directory preferred-dc show -
vserver active-directory discovered-servers show -
vserver active-directory discovered-servers reset-servers -
vserver cifs security show
reset_discovered_servers |
boolean |
query |
False |
Force a rediscovery.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
array[discovered_servers] |
Specifies the discovered servers records. |
fqdn |
string |
Fully qualified domain name. |
name |
string |
Active Directory (AD) account NetBIOS name. |
organizational_unit |
string |
Organizational unit under which the Active Directory account will be created. |
preferred_dcs |
array[preferred_dcs] |
Specifies the preferred domain controller (DC) records. |
security |
svm |
"discovered_servers": [
"domain": "server1.com",
"node": {
"href": "/api/resourcelink"
"name": "node1",
"preference": "preferred",
"server": {
"ip": "7.4.3.1",
"name": "scspk0659102001",
"type": "kerberos"
"state": "ok"
"force_account_overwrite": "",
"fqdn": "server1.com",
"name": "account1",
"organizational_unit": "CN=Test",
"preferred_dcs": [
"fqdn": "test.com",
"server_ip": "4.4.4.4"
"security": {
"advertised_kdc_encryptions": [
"string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
node
_links |
name |
string |
uuid |
string |
active_directory_discovered_server_reference
ip |
string |
The IP address of the server that was discovered. |
name |
string |
Server Name |
type |
string |
The type of the server that was discovered. |
discovered_servers
domain |
string |
The Active Directory domain that the discovered server is a member of. |
node |
preference |
string |
The preference level of the server that was discovered. |
server |
state |
string |
The status of the connection to the server that was discovered. |
preferred_dcs
fqdn |
string |
Fully Qualified Domain Name. |
server_ip |
string |
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address. |
active_directory_security
advertised_kdc_encryptions |
array[string] |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
