Retrieve Active Directory accounts for all SVMs
Retrieves Active Directory accounts for all SVMs to manage and review the directory services associated with your storage virtual machines.
HTTP method and endpoint
GET /protocols/active-directory
Introduced in
ONTAP 9.12
Related ONTAP commands
vserver active-directory show -
vserver active-directory preferred-dc show -
vserver active-directory discovered-servers show
organizational_unit |
string |
query |
False |
Filter by organizational_unit |
name |
string |
query |
False |
Filter by name
discovered_servers.node.name |
string |
query |
False |
Filter by discovered_servers.node.name |
discovered_servers.node.uuid |
string |
query |
False |
Filter by discovered_servers.node.uuid |
discovered_servers.server.type |
string |
query |
False |
Filter by discovered_servers.server.type |
discovered_servers.server.name |
string |
query |
False |
Filter by discovered_servers.server.name |
discovered_servers.server.ip |
string |
query |
False |
Filter by discovered_servers.server.ip |
discovered_servers.preference |
string |
query |
False |
Filter by discovered_servers.preference |
discovered_servers.domain |
string |
query |
False |
Filter by discovered_servers.domain |
discovered_servers.state |
string |
query |
False |
Filter by discovered_servers.state |
fqdn |
string |
query |
False |
Filter by fqdn
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
preferred_dcs.fqdn |
string |
query |
False |
Filter by preferred_dcs.fqdn
preferred_dcs.server_ip |
string |
query |
False |
Filter by preferred_dcs.server_ip |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Active Directory records. |
records |
array[active_directory] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"discovered_servers": [
"domain": "server1.com",
"node": {
"name": "node1",
"preference": "preferred",
"server": {
"ip": "7.4.3.1",
"name": "scspk0659102001",
"type": "kerberos"
"state": "ok"
"force_account_overwrite": "",
"fqdn": "server1.com",
"name": "account1",
"organizational_unit": "CN=Test",
"preferred_dcs": [
"fqdn": "test.com",
"server_ip": "4.4.4.4"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
active_directory_discovered_server_reference
ip |
string |
The IP address of the server that was discovered. |
name |
string |
Server Name |
type |
string |
The type of the server that was discovered. |
discovered_servers
domain |
string |
The Active Directory domain that the discovered server is a member of. |
node |
preference |
string |
The preference level of the server that was discovered. |
server |
state |
string |
The status of the connection to the server that was discovered. |
preferred_dcs
fqdn |
string |
Fully Qualified Domain Name. |
server_ip |
string |
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
active_directory
discovered_servers |
array[discovered_servers] |
Specifies the discovered servers records. |
fqdn |
string |
Fully qualified domain name. |
name |
string |
Active Directory (AD) account NetBIOS name. |
string |
Organizational unit under which the Active Directory account will be created. |
preferred_dcs |
array[preferred_dcs] |
Specifies the preferred domain controller (DC) records. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
