REST API reference
Retrieve Active Directory accounts for all SVMs
Retrieves Active Directory accounts for all SVMs to manage and verify domain relationships within your storage environment.
HTTP method and endpoint
GET /protocols/active-directory
Introduced in
ONTAP 9.12
  • vserver active-directory show
  • vserver active-directory preferred-dc show
  • vserver active-directory discovered-servers show
fqdn
string
query
False
Filter by fqdn
  • maxLength: 254
name
string
query
False
Filter by name
  • maxLength: 15
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
discovered_servers.state
string
query
False
Filter by discovered_servers.state
discovered_servers.server.name
string
query
False
Filter by discovered_servers.server.name
discovered_servers.server.type
string
query
False
Filter by discovered_servers.server.type
discovered_servers.server.ip
string
query
False
Filter by discovered_servers.server.ip
discovered_servers.domain
string
query
False
Filter by discovered_servers.domain
discovered_servers.preference
string
query
False
Filter by discovered_servers.preference
discovered_servers.node.uuid
string
query
False
Filter by discovered_servers.node.uuid
discovered_servers.node.name
string
query
False
Filter by discovered_servers.node.name
preferred_dcs.fqdn
string
query
False
Filter by preferred_dcs.fqdn
  • maxLength: 254
preferred_dcs.server_ip
string
query
False
Filter by preferred_dcs.server_ip
organizational_unit
string
query
False
Filter by organizational_unit
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Active Directory records.
records
array[active_directory]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "discovered_servers": [
          "domain": "server1.com",
          "node": {
            "name": "node1",
          "preference": "preferred",
          "server": {
            "ip": "7.4.3.1",
            "name": "scspk0659102001",
            "type": "kerberos"
          "state": "ok"
      "force_account_overwrite": "",
      "fqdn": "server1.com",
      "name": "account1",
      "organizational_unit": "CN=Test",
      "preferred_dcs": [
          "fqdn": "test.com",
          "server_ip": "4.4.4.4"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
active_directory_discovered_server_reference
ip
string
The IP address of the server that was discovered.
name
string
Server Name
type
string
The type of the server that was discovered.
discovered_servers
domain
string
The Active Directory domain that the discovered server is a member of.
node
node
preference
string
The preference level of the server that was discovered.
server
state
string
The status of the connection to the server that was discovered.
preferred_dcs
fqdn
string
Fully Qualified Domain Name.
server_ip
string
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
active_directory
discovered_servers
array[discovered_servers]
Specifies the discovered servers records.
fqdn
string
Fully qualified domain name.
name
string
Active Directory (AD) account NetBIOS name.
organizational_unit
string
Organizational unit under which the Active Directory account will be created.
preferred_dcs
array[preferred_dcs]
Specifies the preferred domain controller (DC) records.
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
