Retrieve Active Directory accounts for all SVMs
Accesses Active Directory accounts associated with all Storage Virtual Machines (SVMs). This helps you manage and review Active Directory configurations within your storage environment.
HTTP method and endpoint
GET /protocols/active-directory
Introduced in
ONTAP 9.12
Usage notes
Retrieves Active Directory accounts for all SVMs.
Related ONTAP commands
vserver active-directory show -
vserver active-directory preferred-dc show -
vserver active-directory discovered-servers show -
vserver cifs security show
discovered_servers.state |
string |
query |
False |
Filter by discovered_servers.state |
discovered_servers.server.name |
string |
query |
False |
Filter by discovered_servers.server.name |
discovered_servers.server.ip |
string |
query |
False |
Filter by discovered_servers.server.ip |
discovered_servers.server.type |
string |
query |
False |
Filter by discovered_servers.server.type |
discovered_servers.node.uuid |
string |
query |
False |
Filter by discovered_servers.node.uuid |
discovered_servers.node.name |
string |
query |
False |
Filter by discovered_servers.node.name |
discovered_servers.domain |
string |
query |
False |
Filter by discovered_servers.domain |
discovered_servers.preference |
string |
query |
False |
Filter by discovered_servers.preference |
preferred_dcs.fqdn |
string |
query |
False |
Filter by preferred_dcs.fqdn
preferred_dcs.server_ip |
string |
query |
False |
Filter by preferred_dcs.server_ip |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
organizational_unit |
string |
query |
False |
Filter by organizational_unit |
fqdn |
string |
query |
False |
Filter by fqdn
security.advertised_kdc_encryptions |
string |
query |
False |
Filter by security.advertised_kdc_encryptions
name |
string |
query |
False |
Filter by name
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Active Directory records. |
records |
array[active_directory] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"discovered_servers": [
"domain": "server1.com",
"node": {
"name": "node1",
"preference": "preferred",
"server": {
"ip": "7.4.3.1",
"name": "scspk0659102001",
"type": "kerberos"
"state": "ok"
"force_account_overwrite": "",
"fqdn": "server1.com",
"name": "account1",
"organizational_unit": "CN=Test",
"preferred_dcs": [
"fqdn": "test.com",
"server_ip": "4.4.4.4"
"security": {
"advertised_kdc_encryptions": [
"string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
active_directory_discovered_server_reference
ip |
string |
The IP address of the server that was discovered. |
name |
string |
Server Name |
type |
string |
The type of the server that was discovered. |
discovered_servers
domain |
string |
The Active Directory domain that the discovered server is a member of. |
node |
preference |
string |
The preference level of the server that was discovered. |
server |
state |
string |
The status of the connection to the server that was discovered. |
preferred_dcs
fqdn |
string |
Fully Qualified Domain Name. |
server_ip |
string |
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address. |
active_directory_security
array[string] |
svm
_links |
name |
string |
uuid |
string |
active_directory
discovered_servers |
array[discovered_servers] |
Specifies the discovered servers records. |
fqdn |
string |
Fully qualified domain name. |
name |
string |
Active Directory (AD) account NetBIOS name. |
string |
Organizational unit under which the Active Directory account will be created. |
preferred_dcs |
array[preferred_dcs] |
Specifies the preferred domain controller (DC) records. |
security |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
