REST API reference
Retrieve Active Directory accounts for all SVMs
GET /protocols/active-directory
Introduced In: 9.12
Retrieves Active Directory accounts for all SVMs.
  • vserver active-directory show
  • vserver active-directory preferred-dc show
  • vserver active-directory discovered-servers show
  • vserver cifs security show
preferred_dcs.server_ip
string
query
False
Filter by preferred_dcs.server_ip
preferred_dcs.fqdn
string
query
False
Filter by preferred_dcs.fqdn
  • maxLength: 254
fqdn
string
query
False
Filter by fqdn
  • maxLength: 254
security.advertised_kdc_encryptions
string
query
False
Filter by security.advertised_kdc_encryptions
  • Introduced in: 9.17
discovered_servers.server.type
string
query
False
Filter by discovered_servers.server.type
discovered_servers.server.name
string
query
False
Filter by discovered_servers.server.name
discovered_servers.server.ip
string
query
False
Filter by discovered_servers.server.ip
discovered_servers.state
string
query
False
Filter by discovered_servers.state
discovered_servers.domain
string
query
False
Filter by discovered_servers.domain
discovered_servers.node.name
string
query
False
Filter by discovered_servers.node.name
discovered_servers.node.uuid
string
query
False
Filter by discovered_servers.node.uuid
discovered_servers.preference
string
query
False
Filter by discovered_servers.preference
organizational_unit
string
query
False
Filter by organizational_unit
name
string
query
False
Filter by name
  • maxLength: 15
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Active Directory records.
records
array[active_directory]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "discovered_servers": [
          "domain": "server1.com",
          "node": {
            "name": "node1",
          "preference": "preferred",
          "server": {
            "ip": "7.4.3.1",
            "name": "scspk0659102001",
            "type": "kerberos"
          "state": "ok"
      "force_account_overwrite": "",
      "fqdn": "server1.com",
      "name": "account1",
      "organizational_unit": "CN=Test",
      "preferred_dcs": [
          "fqdn": "test.com",
          "server_ip": "4.4.4.4"
      "security": {
        "advertised_kdc_encryptions": [
          "string"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
active_directory_discovered_server_reference
ip
string
The IP address of the server that was discovered.
name
string
Server Name
type
string
The type of the server that was discovered.
discovered_servers
domain
string
The Active Directory domain that the discovered server is a member of.
node
node
preference
string
The preference level of the server that was discovered.
server
state
string
The status of the connection to the server that was discovered.
preferred_dcs
fqdn
string
Fully Qualified Domain Name.
server_ip
string
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address.
active_directory_security
array[string]
svm
_links
_links
name
string
uuid
string
active_directory
discovered_servers
array[discovered_servers]
Specifies the discovered servers records.
fqdn
string
Fully qualified domain name.
name
string
Active Directory (AD) account NetBIOS name.
organizational_unit
string
Organizational unit under which the Active Directory account will be created.
preferred_dcs
array[preferred_dcs]
Specifies the preferred domain controller (DC) records.
security
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
