Retrieve CIFS domain-related information for an SVM
Retrieves CIFS domain-related information for an SVM to view the configurations and initiate asynchronous rediscovery of trusts and reset of discovered servers.
HTTP method and endpoint
GET /protocols/cifs/domains/{svm.uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves the CIFS domain-related information of the specified SVM.
Important notes
GET operation with query parameter rediscover_trusts and reset_discovered_servers returns available CIFS domain configurations and also triggers trusts rediscovery and discovered servers reset asynchronously for that SVM.
Related ONTAP commands
vserver cifs domain preferred-dc show -
vserver cifs domain trusts show -
vserver cifs domain discovered-servers show -
vserver cifs domain name-mapping-search show -
vserver cifs domain schedule show
Learn more
rediscover_trusts |
boolean |
query |
False |
Force the discovery of trusted domains.
reset_discovered_servers |
boolean |
query |
False |
Force a rediscovery.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
array[discovered_servers] |
Specifies the discovered servers records. |
name_mapping |
Specifies the name mapping search records. |
password_schedule |
Specifies the password schedule records. |
preferred_dcs |
array[preferred_dcs] |
Specifies the preferred DC records. |
svm |
trust_relationships |
array[trust_relationships] |
Specifies the trusted domain records. |
"discovered_servers": [
"domain": "test.com",
"node": {
"href": "/api/resourcelink"
"name": "node1",
"preference": "string",
"server_ip": "string",
"server_name": "string",
"server_type": "string",
"state": "string"
"name_mapping": {
"trusted_domains": [
"domain.com"
"password_schedule": {
"schedule_description": "string",
"schedule_last_changed_time": "string",
"schedule_warn_message": "string"
"preferred_dcs": [
"fqdn": "test.com",
"server_ip": "4.4.4.4",
"status": {
"details": "Response time (msec): 111",
"reachable": 1
"svm": {
"name": "svm1",
"trust_relationships": [
"home_domain": "string",
"node": {
"name": "node1",
"string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
656463 |
SVM UUID must be provided for a query on the field rediscover_trusts and reset_discovered_servers. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
node
_links |
name |
string |
uuid |
string |
discovered_servers
domain |
string |
Fully Qualified Domain Name. |
node |
preference |
string |
Server Preference |
server_ip |
string |
Server IP address |
server_name |
string |
Server Name |
server_type |
string |
Server Type |
state |
string |
Server status |
name_mapping
trusted_domains |
array[string] |
password_schedule
schedule_description |
string |
Schedule description. |
schedule_enabled |
boolean |
Is password schedule enabled. |
schedule_last_changed_time |
string |
Last successful password change time. |
schedule_randomized_minute |
integer |
Minutes within which schedule start can be randomized. |
schedule_warn_message |
string |
Warning message in case job is deleted. |
schedule_weekly_interval |
integer |
Interval in weeks for password change schedule. |
status
Status of CIFS preferred domain controller.
details |
string |
Provides a detailed description of the state if the state is 'down' or the response time of the DNS server if the state is 'up'. |
reachable |
boolean |
Indicates whether or not the domain controller is reachable. |
preferred_dcs
fqdn |
string |
server_ip |
string |
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address. |
status |
Status of CIFS preferred domain controller. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
trust_relationships
home_domain |
string |
Home Domain Name |
node |
trusted_domains |
array[string] |
Trusted Domain Name |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
