REST API reference
Retrieve the CIFS domain-related information for an SVM
Retrieves CIFS domain-related information for a specified SVM. This endpoint is useful for accessing current domain configurations and managing CIFS trusts and discovered servers.
HTTP method and endpoint
GET /protocols/cifs/domains/{svm.uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves the CIFS domain-related information of the specified SVM.
Important notes
GET operation with query parameter rediscover_trusts and reset_discovered_servers returns available CIFS domain configurations and also triggers trusts rediscovery and discovered servers reset asynchronously for that SVM.
  • vserver cifs domain preferred-dc show
  • vserver cifs domain trusts show
  • vserver cifs domain discovered-servers show
  • vserver cifs domain name-mapping-search show
  • vserver cifs domain password schedule show
  • vserver cifs domain discovered-servers discovery-mode show
rediscover_trusts
boolean
query
False
Force the discovery of trusted domains.
  • Default value:
boolean
query
False
Force a rediscovery.
  • Default value:
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
ad_domain
ad_domain
Specifies the credentials of a user with permissions to reset the password in the organizational unit for the machine account.
client_id
string
Application client ID of the deployed Azure application with appropriate access to an AKV or EntraId.
discovered_servers
array[discovered_servers]
Specifies the discovered servers records.
name_mapping
name_mapping
Specifies the name mapping search records.
password_schedule
password_schedule
Specifies the password schedule records.
preferred_dcs
array[preferred_dcs]
Specifies the preferred DC records.
server_discovery_mode
string
Specifies the mode of server discovery.
svm
svm
tenant_id
string
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV or EntraId.
trust_relationships
array[trust_relationships]
Specifies the trusted domain records.
  "client_id": "e959d1b5-5a63-4284-9268-851e30e3eceb",
  "discovered_servers": [
      "domain": "test.com",
      "node": {
            "href": "/api/resourcelink"
        "name": "node1",
      "preference": "string",
      "server_ip": "string",
      "server_name": "string",
      "server_type": "string",
      "state": "string"
  "name_mapping": {
    "trusted_domains": [
      "domain.com"
  "password_schedule": {
    "schedule_day_of_week": "Sunday",
    "schedule_description": "string",
    "schedule_last_changed_time": "string",
    "schedule_time_of_day": 36900,
    "schedule_warn_message": "string"
  "preferred_dcs": [
      "fqdn": "test.com",
      "server_ip": "4.4.4.4"
  "server_discovery_mode": "string",
  "svm": {
    "name": "svm1",
  "tenant_id": "c9f32fcb-4ab7-40fe-af1b-1850d46cfbbe",
  "trust_relationships": [
      "home_domain": "string",
      "node": {
        "name": "node1",
        "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
656463
SVM UUID must be provided for a query on the field rediscover_trusts and reset_discovered_servers.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
ad_domain
string
self
node
_links
_links
name
string
uuid
string
discovered_servers
domain
string
Fully Qualified Domain Name.
node
node
preference
string
Server Preference
server_ip
string
Server IP address
server_name
string
Server Name
server_type
string
Server Type
state
string
Server status
name_mapping
trusted_domains
array[string]
password_schedule
string
Day of the week for password change schedule.
string
Schedule description.
schedule_enabled
boolean
Is password schedule enabled.
string
Last successful password change time.
schedule_randomized_minute
integer
Minutes within which schedule start can be randomized.
string
Start time for password change schedule.
string
Warning message in case job is deleted.
schedule_weekly_interval
integer
Interval in weeks for password change schedule.
preferred_dcs
fqdn
string
server_ip
string
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address.
svm
_links
_links
name
string
uuid
string
trust_relationships
home_domain
string
Home Domain Name
node
node
trusted_domains
array[string]
Trusted Domain Name
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
