REST API reference
Retrieve the CIFS domain-related information for an SVM
Retrieves CIFS domain-related information for a specified SVM. This endpoint is useful for accessing current domain configurations and managing CIFS trusts and discovered servers.
HTTP method and endpoint
GET /protocols/cifs/domains/{svm.uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves the CIFS domain-related information of the specified SVM.
Important notes
GET operation with query parameter rediscover_trusts and reset_discovered_servers returns available CIFS domain configurations and also triggers trusts rediscovery and discovered servers reset asynchronously for that SVM.
  • vserver cifs domain preferred-dc show
  • vserver cifs domain trusts show
  • vserver cifs domain discovered-servers show
  • vserver cifs domain name-mapping-search show
  • vserver cifs domain password schedule show
  • vserver cifs domain discovered-servers discovery-mode show
rediscover_trusts
boolean
query
False
Force the discovery of trusted domains.
  • Default value:
boolean
query
False
Force a rediscovery.
  • Default value:
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
discovered_servers
array[discovered_servers]
Specifies the discovered servers records.
name_mapping
name_mapping
Specifies the name mapping search records.
password_schedule
password_schedule
Specifies the password schedule records.
preferred_dcs
array[preferred_dcs]
Specifies the preferred DC records.
server_discovery_mode
string
Specifies the mode of server discovery.
svm
svm
trust_relationships
array[trust_relationships]
Specifies the trusted domain records.
  "discovered_servers": [
      "domain": "test.com",
      "node": {
            "href": "/api/resourcelink"
        "name": "node1",
      "preference": "string",
      "server_ip": "string",
      "server_name": "string",
      "server_type": "string",
      "state": "string"
  "name_mapping": {
    "trusted_domains": [
      "domain.com"
  "password_schedule": {
    "schedule_day_of_week": "Sunday",
    "schedule_description": "string",
    "schedule_last_changed_time": "string",
    "schedule_time_of_day": 36900,
    "schedule_warn_message": "string"
  "preferred_dcs": [
      "fqdn": "test.com",
      "server_ip": "4.4.4.4",
      "status": {
        "details": "Response time (msec): 111",
        "reachable": 1
  "server_discovery_mode": "string",
  "svm": {
    "name": "svm1",
  "trust_relationships": [
      "home_domain": "string",
      "node": {
        "name": "node1",
        "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
656463
SVM UUID must be provided for a query on the field rediscover_trusts and reset_discovered_servers.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
node
_links
_links
name
string
uuid
string
discovered_servers
domain
string
Fully Qualified Domain Name.
node
node
preference
string
Server Preference
server_ip
string
Server IP address
server_name
string
Server Name
server_type
string
Server Type
state
string
Server status
name_mapping
trusted_domains
array[string]
password_schedule
string
Day of the week for password change schedule.
string
Schedule description.
schedule_enabled
boolean
Is password schedule enabled.
string
Last successful password change time.
schedule_randomized_minute
integer
Minutes within which schedule start can be randomized.
string
Start time for password change schedule.
string
Warning message in case job is deleted.
schedule_weekly_interval
integer
Interval in weeks for password change schedule.
status
Status of CIFS preferred domain controller.
details
string
Provides a detailed description of the state if the state is 'down' or the response time of the DNS server if the state is 'up'.
reachable
boolean
Indicates whether or not the domain controller is reachable.
preferred_dcs
fqdn
string
server_ip
string
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address.
status
status
svm
_links
_links
name
string
The name of the SVM.
uuid
string
trust_relationships
home_domain
string
Home Domain Name
node
node
trusted_domains
array[string]
Trusted Domain Name
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
