Retrieve applied central access rules for an SVM
Retrieves central access rules applied to an SVM, providing insight into the access permissions configured for the specified storage virtual machine.
HTTP method and endpoint
GET /protocols/cifs/group-policies/{svm.uuid}/central-access-rules
Introduced in
ONTAP 9.12
Usage notes
Retrieves applied central access rules for specified SVM.
Related ONTAP commands
vserver cifs group-policy central-access-rule show-applied
resource_criteria |
string |
query |
False |
Filter by resource_criteria |
name |
string |
query |
False |
Filter by name
create_time |
string |
query |
False |
Filter by create_time |
current_permission |
string |
query |
False |
Filter by current_permission |
update_time |
string |
query |
False |
Filter by update_time |
description |
string |
query |
False |
Filter by description |
proposed_permission |
string |
query |
False |
Filter by proposed_permission |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of central access rules. |
records |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"create_time": "2018-01-01T12:00:00-04:00",
"current_permission": "O:SYG:SYD:AR(A;;FA;;;WD)",
"description": "rule #1",
"name": "p1",
"proposed_permission": "O:SYG:SYD:(A;;FA;;;OW)(A;;FA;;;BA)(A;;FA;;;SY)",
"resource_criteria": "department",
"svm": {
"name": "svm1",
"update_time": "2018-01-01T12:00:00-04:00"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
Will not be populated for objects that are yet to be applied.
_links |
name |
string |
The name of the SVM. |
uuid |
string |
group_policy_object_central_access_rule
create_time |
string |
Policy creation timestamp. |
string |
Effective security policy in security descriptor definition language format. |
description |
string |
Description about the policy. |
name |
string |
string |
Proposed security policy in security descriptor definition language format. |
resource_criteria |
string |
Criteria to scope resources for which access rules apply. |
svm |
Will not be populated for objects that are yet to be applied. |
update_time |
string |
Last policy modification timestamp. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
