Retrieve applied central access rules for an SVM
GET /protocols/cifs/group-policies/{svm.uuid}/central-access-rules
Introduced In: 9.12
Retrieves applied central access rules for specified SVM.
Related ONTAP commands
vserver cifs group-policy central-access-rule show-applied
update_time |
string |
query |
False |
Filter by update_time |
name |
string |
query |
False |
Filter by name
create_time |
string |
query |
False |
Filter by create_time |
resource_criteria |
string |
query |
False |
Filter by resource_criteria |
description |
string |
query |
False |
Filter by description |
current_permission |
string |
query |
False |
Filter by current_permission |
svm.name |
string |
query |
False |
Filter by svm.name |
proposed_permission |
string |
query |
False |
Filter by proposed_permission |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of central access rules. |
records |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"create_time": "2018-01-01 16:00:00 +0000",
"current_permission": "O:SYG:SYD:AR(A;;FA;;;WD)",
"description": "rule #1",
"name": "p1",
"proposed_permission": "O:SYG:SYD:(A;;FA;;;OW)(A;;FA;;;BA)(A;;FA;;;SY)",
"resource_criteria": "department",
"svm": {
"name": "svm1",
"update_time": "2018-01-01 16:00:00 +0000"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
Will not be populated for objects that are yet to be applied.
_links |
name |
string |
uuid |
string |
group_policy_object_central_access_rule
create_time |
string |
Policy creation timestamp. |
string |
Effective security policy in security descriptor definition language format. |
description |
string |
Description about the policy. |
name |
string |
string |
Proposed security policy in security descriptor definition language format. |
resource_criteria |
string |
Criteria to scope resources for which access rules apply. |
svm |
Will not be populated for objects that are yet to be applied. |
update_time |
string |
Last policy modification timestamp. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
