REST API reference
Retrieve applied central access rules for an SVM
GET /protocols/cifs/group-policies/{svm.uuid}/central-access-rules
Introduced In: 9.12
Retrieves applied central access rules for specified SVM.
  • vserver cifs group-policy central-access-rule show-applied
description
string
query
False
Filter by description
update_time
string
query
False
Filter by update_time
svm.name
string
query
False
Filter by svm.name
name
string
query
False
Filter by name
  • minLength: 1
proposed_permission
string
query
False
Filter by proposed_permission
resource_criteria
string
query
False
Filter by resource_criteria
create_time
string
query
False
Filter by create_time
current_permission
string
query
False
Filter by current_permission
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
max_records
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of central access rules.
records
array[group_policy_object_central_access_rule]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "create_time": "2018-01-01 12:00:00 -0400",
      "current_permission": "O:SYG:SYD:AR(A;;FA;;;WD)",
      "description": "rule #1",
      "name": "p1",
      "proposed_permission": "O:SYG:SYD:(A;;FA;;;OW)(A;;FA;;;BA)(A;;FA;;;SY)",
      "resource_criteria": "department",
      "svm": {
        "name": "svm1",
      "update_time": "2018-01-01 12:00:00 -0400"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
Will not be populated for objects that are yet to be applied.
_links
_links
name
string
uuid
string
create_time
string
Policy creation timestamp.
current_permission
string
Effective security policy in security descriptor definition language format.
description
string
Description about the policy.
name
string
proposed_permission
string
Proposed security policy in security descriptor definition language format.
resource_criteria
string
Criteria to scope resources for which access rules apply.
svm
svm
update_time
string
Last policy modification timestamp.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
