Retrieve a CIFS home directory search path for an SVM
GET /protocols/cifs/home-directory/search-paths/{svm.uuid}/{index}
Introduced In: 9.6
Retrieves a CIFS home directory search path of an SVM.
Related ONTAP commands
cifs server home-directory search-path show
index  |
integer  |
path  |
True  |
Home directory search path index  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
index  |
integer  |
The position in the list of paths that is searched to find the home directory of the CIFS client. Not available in POST.  |
path  |
string  |
The file system path that is searched to find the home directory of the CIFS client.  |
svm  |
  "index": 0,
  "path": "/HomeDirectory/EngDomain",
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
