REST API reference
Retrieve a CIFS home directory search path for an SVM
GET /protocols/cifs/home-directory/search-paths/{svm.uuid}/{index}
Introduced In: 9.6
Retrieves a CIFS home directory search path of an SVM.
  • cifs server home-directory search-path show
index
integer
path
True
Home directory search path index
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
index
integer
The position in the list of paths that is searched to find the home directory of the CIFS client. Not available in POST.
path
string
The file system path that is searched to find the home directory of the CIFS client.
svm
svm
  "index": 0,
  "path": "/HomeDirectory/EngDomain",
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
