REST API reference
Retrieve a CIFS home directory search path for an SVM
Retrieves a CIFS home directory search path for an SVM to understand the directory structure used in CIFS protocol operations.
HTTP method and endpoint
GET /protocols/cifs/home-directory/search-paths/{svm.uuid}/{index}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a CIFS home directory search path of an SVM.
  • cifs server home-directory search-path show
index
integer
path
True
Home directory search path index
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
index
integer
The position in the list of paths that is searched to find the home directory of the CIFS client. Not available in POST.
path
string
The file system path that is searched to find the home directory of the CIFS client.
svm
svm
  "index": 0,
  "path": "/HomeDirectory/EngDomain",
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
