Retrieves a cifs home directory search path of an svm
learn more
doc /protocols/cifs/home-directory/search-paths](#docs-nas-protocols_cifs_home-directory_search-paths)
GET /protocols/cifs/home-directory/search-paths/{svm.uuid}/{index}
Retrieves a CIFS home directory search path of an SVM.
Related ONTAP commands
cifs server home-directory search-path show
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
index |
integer |
path |
True |
Home directory search path index |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
index |
integer |
The position in the list of paths that is searched to find the home directory of the CIFS client. Not available in POST. |
path |
string |
The file system path that is searched to find the home directory of the CIFS client. |
svm |
"index": 0,
"path": "/HomeDirectory/EngDomain",
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
