REST API reference
Retrieve NetBIOS information
Retrieves NetBIOS information to assess and manage network protocol settings associated with CIFS shares.
HTTP method and endpoint
GET /protocols/cifs/netbios
Introduced in
ONTAP 9.11
  • ` vserver cifs nbstat`
suffix
string
query
False
Filter by suffix
time_left
integer
query
False
Filter by time_left
scope
string
query
False
Filter by scope
name_registration_type
string
query
False
Filter by name_registration_type
interfaces
string
query
False
Filter by interfaces
name
string
query
False
Filter by name
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
state
string
query
False
Filter by state
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
wins_servers.state
string
query
False
Filter by wins_servers.state
wins_servers.ip
string
query
False
Filter by wins_servers.ip
mode
string
query
False
Filter by mode
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Records.
records
array[netbios]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "interfaces": [
          "10.10.10.35"
      "mode": "string",
      "name": "CLUSTER_1",
      "name_registration_type": "string",
      "node": {
        "name": "node1",
      "scope": "string",
      "state": "string",
      "suffix": "string",
      "svm": {
        "name": "svm1",
      "time_left": 0,
      "wins_servers": [
          "ip": "10.224.65.20",
          "state": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
server
ip
string
Windows Internet Name Server (WINS) address which manages and maps the NetBIOS name of the CIFS server to their network IP addresses. The IP addresses are IPv4 addresses.
state
string
Specifies the state of the WINS server.
netbios
interfaces
array[string]
mode
string
Specifies the mode in which the NetBIOS name service is configured. The supported values are:
  • p - Point to Point
  • h - Hybrid
  • m - Mixed
  • b - Broadcast
name
string
Specifies the NetBIOS name.
string
Specifies the name registration type.
node
node
scope
string
Specifies the NetBIOS name scope. Scope is used as a name for the set of NetBIOS nodes that participate in a NetBIOS over TCP (NBT) virtual LAN.
state
string
Specifies the registration state of the NetBIOS Name.
suffix
string
Specifies the NetBIOS suffix. A NetBIOS suffix is the 16th character of the 16-character NetBIOS name. The NetBIOS suffix is used by Microsoft Networking software to identify functionality installed on the registered device.
svm
svm
time_left
integer
Specifies the registration time left with WINS, in minutes.
wins_servers
array[server]
List of WINS
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
