Retrieve NetBIOS information
GET /protocols/cifs/netbios
Introduced In: 9.11
Retrieves NetBIOS information.
Related ONTAP commands
vserver cifs nbtstat
Learn more
interfaces |
string |
query |
False |
Filter by interfaces |
suffix |
string |
query |
False |
Filter by suffix |
wins_servers.ip |
string |
query |
False |
Filter by wins_servers.ip |
wins_servers.state |
string |
query |
False |
Filter by wins_servers.state |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
time_left |
integer |
query |
False |
Filter by time_left |
name_registration_type |
string |
query |
False |
Filter by name_registration_type |
mode |
string |
query |
False |
Filter by mode |
name |
string |
query |
False |
Filter by name |
scope |
string |
query |
False |
Filter by scope |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
state |
string |
query |
False |
Filter by state |
return_timeout |
integer |
query |
False |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records. |
records |
array[netbios] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"interfaces": [
"10.10.10.35"
"mode": "string",
"name": "CLUSTER_1",
"name_registration_type": "string",
"node": {
"name": "node1",
"scope": "string",
"state": "string",
"suffix": "string",
"svm": {
"name": "svm1",
"time_left": 0,
"wins_servers": [
"ip": "10.224.65.20",
"state": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
uuid |
string |
server
ip |
string |
Windows Internet Name Server (WINS) address which manages and maps the NetBIOS name of the CIFS server to their network IP addresses. The IP addresses are IPv4 addresses. |
state |
string |
Specifies the state of the WINS server. |
netbios
interfaces |
array[string] |
mode |
string |
Specifies the mode in which the NetBIOS name service is configured. The supported values are:
name |
string |
Specifies the NetBIOS name. |
string |
Specifies the name registration type. |
node |
scope |
string |
Specifies the NetBIOS name scope. Scope is used as a name for the set of NetBIOS nodes that participate in a NetBIOS over TCP (NBT) virtual LAN. |
state |
string |
Specifies the registration state of the NetBIOS Name. |
suffix |
string |
Specifies the NetBIOS suffix. A NetBIOS suffix is the 16th character of the 16-character NetBIOS name. The NetBIOS suffix is used by Microsoft Networking software to identify functionality installed on the registered device. |
svm |
time_left |
integer |
Specifies the registration time left with WINS, in minutes. |
wins_servers |
array[server] |
List of WINS |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
