Retrieve NetBIOS information
Retrieves NetBIOS information to access details about NetBIOS configurations and status in your environment. This is useful for managing and troubleshooting CIFS services on your storage systems.
HTTP method and endpoint
GET /protocols/cifs/netbios
Introduced in
ONTAP 9.11
Related ONTAP commands
vserver cifs nbtstat
Learn more
wins_servers.state |
string |
query |
False |
Filter by wins_servers.state |
wins_servers.ip |
string |
query |
False |
Filter by wins_servers.ip |
time_left |
integer |
query |
False |
Filter by time_left |
suffix |
string |
query |
False |
Filter by suffix |
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
interfaces |
string |
query |
False |
Filter by interfaces |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
state |
string |
query |
False |
Filter by state |
name |
string |
query |
False |
Filter by name |
scope |
string |
query |
False |
Filter by scope |
mode |
string |
query |
False |
Filter by mode |
name_registration_type |
string |
query |
False |
Filter by name_registration_type |
return_timeout |
integer |
query |
False |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records. |
records |
array[netbios] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"interfaces": [
"10.10.10.35"
"mode": "string",
"name": "CLUSTER_1",
"name_registration_type": "string",
"node": {
"name": "node1",
"scope": "string",
"state": "string",
"suffix": "string",
"svm": {
"name": "svm1",
"time_left": 0,
"wins_servers": [
"ip": "10.224.65.20",
"state": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
uuid |
string |
server
ip |
string |
Windows Internet Name Server (WINS) address which manages and maps the NetBIOS name of the CIFS server to their network IP addresses. The IP addresses are IPv4 addresses. |
state |
string |
Specifies the state of the WINS server. |
netbios
interfaces |
array[string] |
mode |
string |
Specifies the mode in which the NetBIOS name service is configured. The supported values are:
name |
string |
Specifies the NetBIOS name. |
string |
Specifies the name registration type. |
node |
scope |
string |
Specifies the NetBIOS name scope. Scope is used as a name for the set of NetBIOS nodes that participate in a NetBIOS over TCP (NBT) virtual LAN. |
state |
string |
Specifies the registration state of the NetBIOS Name. |
suffix |
string |
Specifies the NetBIOS suffix. A NetBIOS suffix is the 16th character of the 16-character NetBIOS name. The NetBIOS suffix is used by Microsoft Networking software to identify functionality installed on the registered device. |
svm |
time_left |
integer |
Specifies the registration time left with WINS, in minutes. |
wins_servers |
array[server] |
List of WINS |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
