REST API reference
Retrieve shadow copies
Accesses shadow copies to view historical versions of files and folders. Use this function to find and restore previous states of shared files in your network environment.
HTTP method and endpoint
GET /protocols/cifs/shadow-copies
Introduced in
ONTAP 9.11
Usage notes
Retrieves Shadowcopies
  • vserver cifs shadowcopy show-shares
shadowcopy_set.uuid
string
query
False
Filter by shadowcopy_set.uuid
uuid
string
query
False
Filter by uuid
client_uuid
string
query
False
Filter by client_uuid
share.name
string
query
False
Filter by share.name
files
string
query
False
Filter by files
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[shadowcopy]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "client_uuid": "abc13450-1f19-40ba-9b82-ebf277517e7e",
      "destination_dir": "/dir2",
      "files": [
        "/vhd1",
        "/vhd2"
      "shadowcopy_set": {
        "uuid": "5f4e19f3-5e2d-11ec-8766-005056a7c134"
      "share": {
        "name": "sh1"
      "source_dir": "/dir1",
      "svm": {
        "name": "svm1",
      "uuid": "fef32805-1f19-40ba-9b82-ebf277517e7e",
      "volume": {
        "name": "volume1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
shadowcopy_set
_links
self_link
uuid
string
share
_links
_links
name
string
Share name
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
The name of the volume where the source and destination directories reside.
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
shadowcopy
_links
_links
client_uuid
string
The universally-unique identifier of the client's shadow copy.
destination_dir
string
The path of the destination directory. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the volume.
files
array[string]
The list of files to shadow copy in the share. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the share.
shadowcopy_set
shadowcopy_set
share
share
source_dir
string
The path of the source directory. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the volume.
svm
svm
uuid
string
The universally-unique identifier of the storage's shadow copy.
volume
volume
with_content
boolean
Specifies what needs to be restored. False specifies the directory only. True indicates the directory and its content.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
