REST API reference
Retrieve shadow copies
Retrieves shadow copies to give you access to previous versions of files and directories on a CIFS share. Use this endpoint when you need to restore or review file states from different points in time.
HTTP method and endpoint
GET /protocols/cifs/shadow-copies
Introduced in
ONTAP 9.11
Usage notes
Retrieves Shadowcopies
  • vserver cifs shadowcopy show-shares
client_uuid
string
query
False
Filter by client_uuid
files
string
query
False
Filter by files
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
shadowcopy_set.uuid
string
query
False
Filter by shadowcopy_set.uuid
uuid
string
query
False
Filter by uuid
share.name
string
query
False
Filter by share.name
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[shadowcopy]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "client_uuid": "abc13450-1f19-40ba-9b82-ebf277517e7e",
      "destination_dir": "/dir2",
      "files": [
        "/vhd1",
        "/vhd2"
      "shadowcopy_set": {
        "uuid": "5f4e19f3-5e2d-11ec-8766-005056a7c134"
      "share": {
        "name": "sh1"
      "source_dir": "/dir1",
      "svm": {
        "name": "svm1",
      "uuid": "fef32805-1f19-40ba-9b82-ebf277517e7e",
      "volume": {
        "name": "volume1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
shadowcopy_set
_links
self_link
uuid
string
share
_links
_links
name
string
Share name
svm
_links
_links
name
string
uuid
string
volume
The name of the volume where the source and destination directories reside.
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
shadowcopy
_links
_links
client_uuid
string
The universally-unique identifier of the client's shadow copy.
destination_dir
string
The path of the destination directory. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the volume.
files
array[string]
The list of files to shadow copy in the share. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the share.
shadowcopy_set
shadowcopy_set
share
share
source_dir
string
The path of the source directory. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the volume.
svm
svm
uuid
string
The universally-unique identifier of the storage's shadow copy.
volume
volume
with_content
boolean
Specifies what needs to be restored. False specifies the directory only. True indicates the directory and its content.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
