Retrieve shadow copies
Retrieves shadow copies to access previous versions of files or folders, which helps in restoring data to a specific point in time.
HTTP method and endpoint
GET /protocols/cifs/shadow-copies
Introduced in
ONTAP 9.11
Usage notes
Retrieves Shadowcopies
Related ONTAP commands
vserver cifs shadowcopy show-shares
Learn more
share.name |
string |
query |
False |
Filter by share.name |
uuid |
string |
query |
False |
Filter by uuid |
files |
string |
query |
False |
Filter by files |
client_uuid |
string |
query |
False |
Filter by client_uuid |
shadowcopy_set.uuid |
string |
query |
False |
Filter by shadowcopy_set.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[shadowcopy] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"client_uuid": "abc13450-1f19-40ba-9b82-ebf277517e7e",
"destination_dir": "/dir2",
"files": [
"/vhd1",
"/vhd2"
"shadowcopy_set": {
"uuid": "5f4e19f3-5e2d-11ec-8766-005056a7c134"
"share": {
"name": "sh1"
"source_dir": "/dir1",
"svm": {
"name": "svm1",
"uuid": "fef32805-1f19-40ba-9b82-ebf277517e7e",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
self_link
self |
shadowcopy_set
_links |
uuid |
string |
_links |
name |
string |
Share name |
svm
_links |
name |
string |
uuid |
string |
volume
The name of the volume where the source and destination directories reside.
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
shadowcopy
_links |
client_uuid |
string |
The universally-unique identifier of the client's shadow copy. |
destination_dir |
string |
The path of the destination directory. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the volume. |
files |
array[string] |
The list of files to shadow copy in the share. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the share. |
shadowcopy_set |
share |
source_dir |
string |
The path of the source directory. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the volume. |
svm |
uuid |
string |
The universally-unique identifier of the storage's shadow copy. |
volume |
The name of the volume where the source and destination directories reside. |
with_content |
boolean |
Specifies what needs to be restored. False specifies the directory only. True indicates the directory and its content. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
