REST API reference
Retrieve nested initiator groups of an initiator group
Retrieves the direct child initiator groups within a specified initiator group, helping you understand the immediate nested structure.
HTTP method and endpoint
GET /protocols/san/igroups/{igroup.uuid}/igroups
Introduced in
ONTAP 9.9
Usage notes
Retrieves nested initiator groups of an initiator group. This API only reports the nested initiator groups that are direct children of the initiator group. Further nested initiator groups are reported by their direct parent initiator group.
  • lun igroup show
igroup.uuid
string
path
True
The unique identifier of the parent initiator group.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[igroup_nested]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "igroup": {
      "name": "igroup1",
Status: Default
ONTAP Error Response Codes
Error Code Description
5374852
The initiator group specified in the URI does not exist.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
igroup
_links
_links
uuid
string
records
_links
_links
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
igroup_nested
_links
_links
igroup
igroup
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
