Retrieve nested initiator groups of an initiator group
Accesses the nested initiator groups directly associated with a specified initiator group. Use this to understand the immediate hierarchy of initiator groups within your storage configuration.
HTTP method and endpoint
GET /protocols/san/igroups/{igroup.uuid}/igroups
Introduced in
ONTAP 9.9
Usage notes
Retrieves nested initiator groups of an initiator group. This API only reports the nested initiator groups that are direct children of the initiator group. Further nested initiator groups are reported by their direct parent initiator group.
Related ONTAP commands
lun igroup show
Learn more
igroup.uuid |
string |
path |
True |
The unique identifier of the parent initiator group. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[igroup_nested] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"igroup": {
"name": "igroup1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374852 |
The initiator group specified in the URI does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
igroup
_links |
uuid |
string |
records
_links |
name |
string |
The name of the initiator group. |
uuid |
string |
The unique identifier of the initiator group. |
igroup_nested
_links |
igroup |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
