Retrieve nested initiator groups of an initiator group
Retrieves the nested initiator groups that are directly associated with a specific initiator group. This is useful when you need to understand the immediate hierarchy and relationships within your storage environment.
HTTP method and endpoint
GET /protocols/san/igroups/{igroup.uuid}/igroups
Introduced in
ONTAP 9.9
Usage notes
Retrieves nested initiator groups of an initiator group.
This API only reports the nested initiator groups that are direct children of the initiator group. Further nested initiator groups are reported by their direct parent initiator group.
Related ONTAP commands
lun igroup show
Learn more
igroup.uuid |
string |
path |
True |
The unique identifier of the parent initiator group. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[igroup_nested] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"igroup": {
"name": "igroup1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374852 |
The initiator group specified in the URI does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
igroup
_links |
uuid |
string |
records
_links |
name |
string |
The name of the initiator group. |
uuid |
string |
The unique identifier of the initiator group. |
igroup_nested
_links |
igroup |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
