Retrieve Vscan events
Retrieves Vscan events generated by the cluster to capture important events. Accessing these events helps you monitor and respond to security-related activities within your storage environment.
HTTP method and endpoint
GET /protocols/vscan/{svm.uuid}/events
Introduced in
ONTAP 9.11
Usage notes
Retrieves Vscan events, which are generated by the cluster to capture important events.
Related ONTAP commands
vserver vscan show-events
vendor |
string |
query |
False |
Filter by vendor |
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
interface.uuid |
string |
query |
False |
Filter by interface.uuid |
interface.ip.address |
string |
query |
False |
Filter by interface.ip.address |
interface.name |
string |
query |
False |
Filter by interface.name |
file_path |
string |
query |
False |
Filter by file_path |
event_time |
string |
query |
False |
Filter by event_time |
disconnect_reason |
string |
query |
False |
Filter by disconnect_reason |
type |
string |
query |
False |
Filter by type |
version |
string |
query |
False |
Filter by version |
server |
string |
query |
False |
Filter by server |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[vscan_event] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"disconnect_reason": "string",
"event_time": "2021-11-25T04:29:41.606Z",
"file_path": "/1",
"interface": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"node": {
"name": "node1",
"server": "192.168.1.1",
"svm": {
"name": "svm1",
"type": "string",
"vendor": "mighty master anti-evil scanner",
"version": "1.0"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
Address of the interface used for the Vscan connection.
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
node
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
vscan_event
disconnect_reason |
string |
Specifies the reason of the Vscan server disconnection. The available values are:
event_time |
string |
Specifies the Timestamp of the event. |
file_path |
string |
Specifies the file for which event happened. |
interface |
Address of the interface used for the Vscan connection. |
node |
server |
string |
Specifies the IP address of the Vscan server. |
svm |
type |
string |
Specifies the event type. |
vendor |
string |
Specifies the scan-engine vendor. |
version |
string |
Specifies the scan-engine version. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
