Retrieve Vscan events
Retrieves Vscan events to review important occurrences generated by the cluster. This helps you monitor and manage the security of your storage environment effectively.
HTTP method and endpoint
GET /protocols/vscan/{svm.uuid}/events
Introduced in
ONTAP 9.11
Usage notes
Retrieves Vscan events, which are generated by the cluster to capture important events.
Related ONTAP commands
vserver vscan show-events
vendor |
string |
query |
False |
Filter by vendor |
svm.name |
string |
query |
False |
Filter by svm.name |
file_path |
string |
query |
False |
Filter by file_path |
server |
string |
query |
False |
Filter by server |
type |
string |
query |
False |
Filter by type |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
version |
string |
query |
False |
Filter by version |
interface.ip.address |
string |
query |
False |
Filter by interface.ip.address |
interface.name |
string |
query |
False |
Filter by interface.name |
interface.uuid |
string |
query |
False |
Filter by interface.uuid |
disconnect_reason |
string |
query |
False |
Filter by disconnect_reason |
event_time |
string |
query |
False |
Filter by event_time |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[vscan_event] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"disconnect_reason": "string",
"event_time": "2021-11-24 23:29:41 -0500",
"file_path": "/1",
"interface": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"node": {
"name": "node1",
"server": "192.168.1.1",
"svm": {
"name": "svm1",
"type": "string",
"vendor": "mighty master anti-evil scanner",
"version": "1.0"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
Address of the interface used for the Vscan connection.
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
node
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
uuid |
string |
vscan_event
disconnect_reason |
string |
Specifies the reason of the Vscan server disconnection. The available values are:
event_time |
string |
Specifies the Timestamp of the event. |
file_path |
string |
Specifies the file for which event happened. |
interface |
Address of the interface used for the Vscan connection. |
node |
server |
string |
Specifies the IP address of the Vscan server. |
svm |
type |
string |
Specifies the event type. |
vendor |
string |
Specifies the scan-engine vendor. |
version |
string |
Specifies the scan-engine version. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
