REST API reference
Retrieve Vscan events
Accesses Vscan events generated by the cluster, capturing important occurrences for review and analysis.
HTTP method and endpoint
GET /protocols/vscan/{svm.uuid}/events
Introduced in
ONTAP 9.11
Usage notes
Retrieves Vscan events, which are generated by the cluster to capture important events.
  • vserver vscan show-events
consecutive_occurrence_count
integer
query
False
Filter by consecutive_occurrence_count
  • Introduced in: 9.18
vendor
string
query
False
Filter by vendor
server
string
query
False
Filter by server
type
string
query
False
Filter by type
version
string
query
False
Filter by version
svm.name
string
query
False
Filter by svm.name
event_time
string
query
False
Filter by event_time
disconnect_reason
string
query
False
Filter by disconnect_reason
file_path
string
query
False
Filter by file_path
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
interface.uuid
string
query
False
Filter by interface.uuid
interface.name
string
query
False
Filter by interface.name
interface.ip.address
string
query
False
Filter by interface.ip.address
scan_engine_status
integer
query
False
Filter by scan_engine_status
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[vscan_event]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "consecutive_occurrence_count": 2,
      "disconnect_reason": "string",
      "event_time": "2021-11-25 04:29:41 +0000",
      "file_path": "/1",
      "interface": {
        "ip": {
          "address": "10.10.10.7"
        "name": "lif1",
      "node": {
        "name": "node1",
      "scan_engine_status": 333300005,
      "server": "192.168.1.1",
      "svm": {
        "name": "svm1",
      "type": "string",
      "vendor": "mighty master anti-evil scanner",
      "version": "1.0"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ip
IP information
address
string
IPv4 or IPv6 address
interface
Address of the interface used for the Vscan connection.
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
node
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
uuid
string
vscan_event
integer
Specifies the consecutive occurrence count of the event.
disconnect_reason
string
Specifies the reason of the Vscan server disconnection. The available values are:
  • na Not applicable
  • vscan_disabled Vscan disabled on the SVM
  • no_data_lif SVM does not have data lif on the node
  • session_uninitialized Session not initialized
  • remote_closed Closure from Server
  • invalid_protocol_msg Invalid protocol-message received
  • invalid_session_id Invalid session-id received
  • inactive_connection No activity on connection
  • invalid_user Connection request by invalid user
  • server_removed Server removed from the active scanner-pool
event_time
string
Specifies the Timestamp of the event.
file_path
string
Specifies the file for which event happened.
interface
interface
node
node
scan_engine_status
integer
Specifies the status code of the scan-engine for the event. This field is only generated when there is a proper response from the scan-engine.
server
string
Specifies the IP address of the Vscan server.
svm
svm
type
string
Specifies the event type.
vendor
string
Specifies the scan-engine vendor.
version
string
Specifies the scan-engine version.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
