REST API reference
Retrieve user accounts in the cluster
Retrieves a list of user accounts in the cluster to review and manage who has access.
HTTP method and endpoint
GET /security/accounts
Introduced in
ONTAP 9.6
  • security login show
password_hash_algorithm
string
query
False
Filter by password_hash_algorithm
  • Introduced in: 9.11
owner.uuid
string
query
False
Filter by owner.uuid
  • Introduced in: 9.7
owner.name
string
query
False
Filter by owner.name
scope
string
query
False
Filter by scope
role.name
string
query
False
Filter by role.name
applications.authentication_methods
string
query
False
Filter by applications.authentication_methods
applications.application
string
query
False
Filter by applications.application
applications.second_authentication_method
string
query
False
Filter by applications.second_authentication_method
locked
boolean
query
False
Filter by locked
comment
string
query
False
Filter by comment
ldap_fastbind
boolean
query
False
Filter by ldap_fastbind
name
string
query
False
Filter by name
  • maxLength: 64
  • minLength: 3
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[account]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "applications": [
          "application": "string",
          "authentication_methods": [
            "string"
          "second_authentication_method": "string"
      "comment": "string",
      "name": "joe.smith",
      "owner": {
        "name": "svm1",
      "password_hash_algorithm": "sha512",
      "role": {
        "name": "admin"
      "scope": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
account_application
application
string
Applications
array[string]
string
An optional additional authentication method for MFA. This only works with SSH as the application. It is ignored for all other applications.
owner
Owner name and UUID that uniquely identifies the user account.
_links
_links
name
string
The name of the SVM.
uuid
string
role
_links
_links
name
string
Role name
account
_links
_links
applications
array[account_application]
comment
string
Optional comment for the user account.
ldap_fastbind
boolean
Optional property that specifies the mode of authentication is LDAP Fastbind.
locked
boolean
Locked status of the account.
name
string
User or group account name
owner
owner
string
Optional property that specifies the password hash algorithm used to generate a hash of the user's password for password matching.
role
role
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
